hi there
getting error messages from the camera an a37
check the lens attachement if the lens is not supported use the custom menu
when pressing the fn function its saying lens not attached correctly attach correctly
everything is attached as should be ,been ok since we bought it in december until now ,any ideas ?
Hi powerkiter, welcome to the Sony Forums
That doesn't sound right and certainly isn't something we hear a lot about on the forums. If this is a Sony a-mount lens (such as a 'kit' lens bought with the camera) there should be no problem getting it repaired.
You'll need to register it for a repair online; see this thread for details: https://www.sony.co.uk/discussions/message/651957#651957
Mick
