A6000 with Tamron B011 18/200 mm. question
sebastianpons
Hi. Short question. Do I need some sort of firmware for using this lens? It works fine but when I look in the "version" tab, I only get the camera version (firmware update), and not even a field for lens.... Is this normal? Please help me/    Sebastian
[Edited for privacy reasons]
3 REPLIES 3
Sean_Mc
Moderator
Hi Sebastian,
I'm looking into this for you and will get back to you soon.  In the meantime perhaps another member may have the answer for you.
Best wishes,
Sean Mc
Win_88
Specialist
Hi sebastianpons,
As far as I know, the functionality of non-Sony lenses is not guaranteed with Sony cameras, so there isn't really a dedicated software to install for the Tamron you have.
That being said, it's always best to ensure the camera is up to date anyway.
Win_88
sebastianpons
Thank you for your answer. I understand, but I've read somewere that tamron and sony (the 18/200 mm.) are the same lens with different brand name. So now I'm asking myself if it would be possible to install the sony 18/200 firmware to "force" the camera to recognize the lens.
As it is now, there is not mention of a lens in the version check, neither it shows in the exif file of a picture taken with it.
Any help/thoughts will be greatly apreciated.
sebastian
