I have an Alpha 100 and I received a note via email regarding a9 firmware upgrade which prompted me to identify mine. I do not have the latest version (1.04) but have 1.02. The software is no longer available and in any case that which would be available looks as if it would not be able to be download to my MBP as I am running macOS 10.14.4.
Any idea how I can get round this? Is it worth the hassle of the upgrade anyway?
Hi David,
I'm looking into this for you and will update the thread as soon as I have an answer.
Best wishes,
Sean Mc
Thanks
Hello David,
Not sure if there are any workarounds for this. I'd personally suggest that you try to download it using any other PC. Maybe a Windows PC. this would be much easier.
Cheers,
Vanilla_
Hello Vanilla,
Please see - https://www.sony.co.uk/electronics/support/downloads/Z0005335
This page indicates that ;
... I dont think Mac or PC can solve this if the update is not available online! The same message appears on the page for Windows!!
