I've just upgraded from the A77 to the A77ii and I'm inding the shutter button very 'mushy', there's no definite 'stop' on half press and I have to say I don't find it as easy to focus lock because of this, I have ended up taking the shot on a couple of occasions. Is this normal for the A77ii or is mine faulty?
The "mushy" shutter button has been implemented this way deliberately to avoid a "small movement" when fully pressing the shutter button. It has been this way for several generations of (high end) Sony Alpha cameras.
It needs some getting used to, but it helps reducing unnecessary hard pressing movement which could cause blurred images
It was well received when it first appeared on Sony Alpha's!
On the A700, A77 and A99 it's all the same, I have or had these cameras.
Glad to see you got used to it! Enjoy!
