I bought the NEX_6L for its wireless functionality but it is showing as disabled on the menu - what do i need to do to enable it
Hi lindacn, welcome to the Sony Forums
It would be helpful to have a few more details in order to try and help you get things working. I presume you've successfully configured the camera to work with your home WiFi network, and it's just the TV menu which shows it as disabled?
Can you also confirm you're using the latest NEX-6 firmware? http://www.sony.co.uk/support/en/product/NEX-6/updates
If you're using a Mac there's an additional download on that page to update WiFi connectivity.
Mick
Either the SD card contains no images or no card at all is inserted in the camera
