Bluetooth remote control
profile.country.FI.title
Jaku71
My TV lose Bluetooth connect to my remote control. How could I pair them back? I can’t go to tv settings to choose Bluetooth 😫
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi Jaku71,
welcome to the Sony User Community..
If you can post which model TV you have it may help someone provide you with some help..
3 REPLIES 3
Thalamus.
Champion
Hi Jaku71,
Jaku71
Yes, model is not easy to check, because I don’t have working remote control. But 75 or 80” Bravia it is 🙃
daveyh64
Enthusiast
The model number of your TV should be on the white label at the back of the TV if that is accessible.
A lot of Sony TVs come with two remote controls, did your TV.
One remote is a small plastic thing that is Infra Red only you can use that remote to set up bluetooth so
you can pair with the bluetooth remote control.
