Does XG9005 work with Sonos Beam?
DavidLB
The height of the Bean is only a mm or two lower than the IR sensor. I'm wondering if anyone has had issue with it blocking the signal. Also, I read on another post that some people have issues with Hdmi Arc connection. If you have any suggestions I'd appreciate your thoughts...
2 REPLIES 2
Hi DavidLB,
If the soundbar is lower than the IR sensor there shouldn't be a problem with the remote.
In terms of HDMI connection it should work fine. However, we have some customers that faced issues with their Sonos product in combination with Sony TVs
By the way, the HT-XF9000 is also a great soundbar and fits nicely under your TV:
https://www.sony.co.uk/electronics/sound-bars/ht-xf9000
DavidLB
Hi Peter,
Thanks for your reply. I've looked at that specific Sony sound bar but my XG9005 doesn't have Dolby Atmos /eArc so I presumed I wouldn't benefit from the sound bar's Atmos feature.
