Have to keep re connecting blue tooth headphones,
Normski4ash
Sony Bravia, Turn TV on turn headphones on and I go into settings, bluetooth and pair the headphones with the TV. Works fine.
My problem is I have to go into the settings and reconnect my headphones every time I turn the headphones on !
Used to be the case that they would automatically pair & connect, now for some reason they won't !
2 REPLIES 2
Marino.Manolo
Try to reboot Android TV by keeping pressed Power/OFF on remote...
rooobb
@Normski4ash do you use your headphone also with other devices?
