I have problem in language
Behnam
How to add persian or farsi language or keyboard to sony LED kd49xf7005
The language list is not available
Tags (1)
11 REPLIES 11
Sean_Mc
Moderator
Hi there,
I'm looking into this for you and will update the thread as soon as I have more information.
Best wishes,
Sean Mc
Vanilla_
Contributor
Hello Behnam,
I don't think you can add more languages to the pre-loaded ones. The keyboard will either follow the same system language, or you can select a different language (Only from the same list).
Vanilla_
Behnam
schade
Adding a language on Android does not have to be difficult :unamused:
Vanilla_
Contributor
Hello again Behnam,
I hear you. It doesn't seem that your KD-49XF7005 is an Android TV. I looked up the specifications of this model and it's running Linux: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kd-49xf7005
Regards,
Vanilla_
Behnam
What should I do?
Does not Sony's customer service help me?:sweat:
Vanilla_
Contributor
Hi Behnam,
I'll try to pass on your feedback regarding this to Sony.
Regards,
Vanilla_
Behnam
This is a problem that the device is not compatible with different languages :neutral:
Thankful
Marino.Manolo
Display language for that model:
BULGARIAN / CATALANO / CZECH / DANISH / GERMAN / GREEK / ENGLISH / SPANISH / ESTONIA / FINLAND / FRENCH / JEWISH / CROATIAN / HUNGARIAN / ITALIAN / Kazakhstan / LITHUANIAN / LATVIAN / DUTCH / NORWEGIAN / POLISH / PORTUGUESE / ROMANIAN / RUSSIAN / SLOVAK / SLOVENIA / SERBIA / SWEDISH / TURKISH / UKRAINIAN / BOSNIAN / MACEDONIAN
Manolo
Behnam
Yes, I know, but I have to be able to add other languages ​​to the keyboard.
Device language is not important, but it's important in Keyboard
