I have the following Sony Bravia tv
KD-49XE8396
since 2017 and recently after an android software update the remote seems to act a lot differently than before. It is not the battery’s I have changed them but some times it doesn’t react when I press it then it takes the volume up very high or low very annoying will this be fixed in a later software update or do I need a new remote?
Thanks in advance.
Hi Steve,
Have you tried a reset on your TV which should resolve this issue. You can see more details on how to perform this here.
Let me know how you get on.
Best wishes,
Sean
Hi Sean
Thanks for the reply unfortunately it is still the same after a factory reset. I have also tried new batteries, I think the fault seems to be more with the remote. Do you have a link where I could buy a replacement I have had the tv almost two years now, and I expect its probably not covered by the warranty now.
Steve
Hi Residentsteve,
Did you try changing the remote control batteries?
Cheers,
The_Black_Rose
He says he has, in the post you were replying to.
But we have only his word for that, of course.... 😜
A simple way to check an infrared remote is to point it to a smartphone camera....
Hi Royabrown2,
Apologies! I think I've missed that part. I'd say do a remote control camera test then as suggested by rooobb to know if that's the remote or the software of the TV.
The steps are available here: https://www.sony.co.uk/electronics/support/articles/00025283
Cheers,
The_Black_Rose
