KD55XG8196 Help Guide pdf
TheLastSnowman
Will Sony be producing a pdf for the Help Guide for the XG81 series, the web version is a pain?
Tags (2)
1 ACCEPTED SOLUTION
Accepted Solutions
LightFoot
Specialist
Hi @TheLastSnowman
If you look at the first page of the Help Guide Web Version you should see If you want to print the complete Help Guide, see “Help Guide (Print Version)
You can print it or print to pdf. Note you will lose the links.
2 REPLIES 2
LightFoot
Specialist
Hi @TheLastSnowman
TheLastSnowman
Yes thanks, printed/downloaded as a pdf 😀
