Plex Problem on 55XE9305
PietreS
I purchased a KD-55XE9305 and was advised in store I can add my NAS box via Plex in the apps. After spending an age thinking I was daft, I am still unable to find a Plex app on the tv. Am I going crazy? Is there a Plex app available for this tv?
3 REPLIES 3
jumpsuit
Hi @PietreS
There is a Plex app available, search in the Google Play Store App
on your TV :slight_smile:
PietreS
Thank for the advice. I have installed the app as advised and all was funky. I turned off the tv and went back to watch some movies from my NAS and the app was nowhere to be found. I would have thought the app would automatically add to the apps when I turn on the tv. So have I made an error somewhere in adding the app?
jumpsuit
Hi @PietreS :slight_smile:
If you managed to install and run it fine (funky is such a good word :D)
then it should still be visible.
Just out of interest has your TV updated recently?
