Remote control 'TV' button switches to YouView aerial), how to switch to HDM1 instead?
Burpman
I have found under Settings, External Input, you can configure the TV button, Howeve this function is greyed out and not selectable. How do I configure this to use HDMI1 input as default?
TV is SONY BRAVIA KD49XD8305BU
Thanks.
Tags (2)
2 ACCEPTED SOLUTIONS
Accepted Solutions
Anonymous
Not applicable
Hi there
This option is unavailable in YouView mode.  YouView would need to be disabled to use this feature.
I have just tested to see if you could disable YouView, change the setting and then re-enable YouView again - unfortunately not, it goes back to the default 'Digital' input doing this.
Anonymous
Not applicable
Hi there
To disable YouView
  1. Press [Home] button on the remote control
  2. Go to 'Settings'
  3. Go to 'Channel Setup'
  4. Go to 'YouView Setup'
  5. Select 'Disable YouView'
  6. Select 'Yes' to confirm
PS: You're Welcome :slight_smile:
3 REPLIES 3
Anonymous
Not applicable
Hi there
Burpman
Thanks for the very quick reply Quinnicus.
Can you let me know how to disable YouView please - only got the set recently and havent navigated all menu's!
Many thanks for you help.
Anonymous
Not applicable
Hi there
To disable YouView
  2. Go to 'Settings'
