Sony OLED AG8 cast to device
jamesriley94
Since the latest update a couple of weeks ago I've been unable to 'cast to device' from either my desktop or laptop on the same network. Both worked fine prior to the update.
I've tried on both my 2.4Ghz and 5Ghz wireless connections and also with the desktop wired (all these previously worked before the update).
Is anyone else having this issue? Starting to regret not spending more and getting the AG9!
Thanks
1 REPLY 1
Marino.Manolo
After an update, is suggested by Sony a Factory Reset, you can try before...
