TV loses connection to soundbar
Tarpii
Hi, Since the last update my Kdl w43-755 has started to regularly drop connection to my soundbar:  Sony HT-XT100. I'm struggling to narrow down the trigger for the sound to switch back to TV speakers (powering on TV is fine and auto standby is off on the soundbar) I think it might be switching sources as it happened tonight after switching from Netflix to TV without exiting the app, but there's definitely a bug here where there wasn't in Marshmallow
5 REPLIES 5
EdwinaU
Moderator
Hi Tarpii,
I will look into this further and update you when there is more information. Meanwhile, maybe some other community members will have some advice for you.
Best wishes,
Ed
Win_88
Specialist
Hi Tarpii,
Have you tried a different HDMI cable? If you have and the same exact thing happens, I'd recommend trying to clear the cache by going to Settings > Storage & reset > Internal Storage then clear the cached data.
Also, make sure that Audio system is selected as the audio output: Settings > Sound > Speakers > Audio system.
It would also be a good idea to test a digital optical connection between the TV and sound bar as a test if possible.
Win_88
Tarpii
Thanks Win_88,
I have not changed or moved the HDMI cable since upgrading the software,
but I will consider changing it. If I were to use an optical connection,
could I expet te soundbar to power on with with TV, I thought this was a
HDMI(CEC) only feature?
Win_88
Specialist
Hi Tarpii,
The auto power on is a HDMI feature only so the soundbar won't turn on with the TV while using digital optical.
Win_88
Tarpii
Happened again today - powered the TV on and the soundbar did not power up.
I will try to dig out the optical cable tonight and see if it performs better by leaving the soundbar on constantly.
