I have a bravia kdl 55w809c running latest firmware
I can use voice search from tv side view app but my question is this
Can I simply buy a newer remote with the voice search button? (save me pulling out phone and loading app etc)
Will this work with my tv?
Thanks in advance
Hi there,
We're taking a look at this for you now, and we'll be back with a response for you soon.
Thanks,
Owen
Hi again,
Yes - it's possible to use a remote control with Voice Search. We recommend the RMF-TX100E, which is perfectly compatible with your television: https://www.sony.co.uk/electronics/televisions-remotes-selectors-cameras/rmf-tx100e.
Hope this helps,
Owen
