XD9305 - remote battery life
chrisc383
Hi
I have standard remote, model RMF-TX200E.
From some time - I don't know exactly when, battery life went to 20-25 days when using normal betteries, 14-18 with rechargable ones.
I upgraded quite late to the last Android version (remembering various issues with 6.0), possibly in December and not long after that I think I started experiencing problems.
Remote has SW version 5.3.14.018
TV has 3.925
I tried re-paring the remote, activating and deactivating voice controls - nothing seems to help.
Some ideas maybe what can be done?
thanks
Chris
3 REPLIES 3
Sean_Mc
Moderator
Hi Chrisc383,
Can you check that your firmware version is  indeed up todate?
Thanks,
Sean Mc
chrisc383
Yes, TV firmware is surely the latest. As for the remote - I clicked on the update in TV settings, then I was told it's the latest version.
Pascale_F
Moderator
Hi Chris,
I think it's best to contact Sony Support about this here.
Thanks,
Pascale_F
