I got problem while updating Android 4.2.2 16.0.B.2.13 firmware using PC Companion
hemanths94
I got problem while updating Android 4.2.2 16.0.B.2.13 firmware using PC Companion  and then my phone is not working.Now it just show the sony text  on screen and it doesn't turn off or turn on Slightly_frowning_Face :'( .please someone help what to do now??
Tags (2)
21 REPLIES 21
_V_
I am getting the same problem, the phone is not turning off and only SONY text is showing on the screen, plz help guys Slightly_frowning_Face
_V_
I have d/l and installed the Update Service but the very first point it says 'Turn Off the phone and wait for 30 seconds'. Now when my phone is totally hanged and showing only the SONY text how can turn off the phone? I tried resetting phone by pressing the reset button located at the back of of the phone but it only restart the phone i.e. screen goes blank when i press the reset button but as soon as i leave the button the SONY text comes back and nothing happens anymore. I am totally screwed up Slightly_frowning_Face Please help
profile.country.RO.title
_alexdon_
If you press that button,it should force the phone to shutdown.If you cannot manage to do that,stop by a sony service.
alexdon
HardCharger
I'm having the same issue only I use a Mac instead of a PC. I cannot update from the phone as it keeps telling me to use a PC. Any ideas?
Tags (1)
_alexdon_
Download bridge for MAC.
alexdon
HardCharger
I already have bridge for Mac but there is no opton there for updating the phone which really frustrates me. Well none that I can see anyway. When I go to preferences to update, it just says that bridge is updated. If there is an option to update the phone, it is not obvious from the options provided.
Any assistance would be appreciated.
Thanks.
_V_
Thanks for d reply buddy, but that didn't helped. So I tried this method: I pressed the switch off button & volume up button together for 10 seconds and it worked! Phone has switched off nicely. I then used the update service and all is done. Now my Xperia C is working perfectly, I m very happy 🙂
khus123
my sony xperia c phone has stuck at sony text... it is not turning off and turning on...hat to do to make it work properlly again...
i m so worried.... how can i use PC Companion or update service because both need phone connectivity... which is not possible because phone has stuck... please help me... how to fix it
i have tried volume up + power button and volume down button method too...
rubik777
"  my sony xperia c phone has stuck at sony text... it is not turning off and turning on...hat to do to make it work properlly again...
i have tried volume up + power button and volume down button method too...  "
SAME HERE !!! What I'm supposed to do now??? Bring it for repair and stay 15 days without phone? All data will be lost? And this because I wanted to go for official update trough official PC Companion ?
http://www.sonymobile.com/gb/tools/update-service/
And now this !!!
"Update Service support has ended
As from 21st July 2014, the Update Service application is no longer supported. To update the software in your device, use PC Companion instead."
HELP !!! Waiting for reply !
jalu
I followed the steps. Bt still pc companion is not detecting my phone Slightly_frowning_Face
