- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I own a HDR-SR1E 30GB HDD HD camcorder (now old school but one of the first HD camera's available by Sony), this has an Active interface shoe on top of the unit for which I have a HVLHIRL.CE7 video IR / Light that fits straight on. I am considering the new FDR-AX100 4K Camcorder which has a Multi interface shoe.
Can anyone tell me if my light will fit straight on to this device or has Sony changed the type of shoe fitting as well as the name please ?
If it ain't broke don't fix it
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi again,
I think I have answered my own question ! So if anyone else has a similar issue here is the solution:
This is an adapter that will make Active interface products fit the new Multi interface shoe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi again,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Jonnie.
Are you saying that you have the FDRAX100 and that by using the Sony shoe adapter that you are able to fit standard equipment onto it?
I have the FDRAX100 but I'd like occasionaly to be able to use a video light on it in really low light conditions but I can't see a way to fit my existing light onto the multi shoe.
Cheers Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Martin,
No, I am sorry if I misled you, I don't actually own the AX100. I was considering it and whilst researching I wondered if my existing light would 'snap' onto the shoe as Sony have changed the fitting. I found the adapter which you can see for yourself by following the link. If you are still unsure I would advise that you contact Sony help line to confirm that it will work.
How is the camera, do you own a 4K TV to play back your footage ?
Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I now have both the Sony shoe adapter and the HVLLEIR1.CE7 Sony light but find that I don?t need the adapter to fit the Sony light and that the adapter doesn?t ?adapt? to a standard size shoe fitting anyway so I can?t fit my old video light to it because the shoe size on the FDX AX100 and on the adapter is much smaller than a ?usual? shoe size.
So I now have the VVLLEIR1.CE7 light on the FDX AX100 and a bog standard cheapo light on my new Sony PXW AX160 - no adapters required.
Good luck
Martin Waring
Magician | Videographer | Web designer
