Podziel się wrażeniami!
Don’t know if it’s a fault or just normal for this model but my fx100 v6 seems extra slow in shutting down after pressing the off button.anyone else experiencing the same?
Rozwiązane! Idź do rozwiązania.
Hi Charioteer,
Thanks for the model information, we'll check this and get back to you when we can.
Maybe some community members will also have some feedback for you.
Best wishes,
Ed
Thanks a lot,that seems to have done the trick ,much quicker closing now.
Regards
Hi Charioteer,
Welcome to the community.
Can you check the model number of your product and let us know so we can look into this for you?
Thanks,
Ed
Hi the model is DSC-RX100V6
and it’s not so much a problem but more of an irritation at the slower shutdown .
Hi charioteer1,
Welcome to our community!
I haven't came across any reported regarding slow shut down on this model before. Could you more specific on how slow it is as in how many seconds does it take? Also, is it slow when switching it on or not?
Regards,
Batee5
Hi charioteer1,
Could you try to take the SD card out then try to reset it by following these instructions? Let us know if this made any difference?
Regards,
Batee5
