- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Charging Ereader
My reader PRS-350 will not charge while plugged into electric socket but using same connection it will charge through the computer. Any idea what is wrong?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Presumeably you are plugging your USB lead into an appropriate USB 3-pin charger adaptor ? Or is it a dedicated Sony charger plug ?
If the same lead charges via PC, but fails via mains, the adaptor's the problem.
Try your phone charger, sat nav, etc... to see if that works - but NOT if it's anything of an Apple persuasion. The two don't like each other ! You can check with either the manual or Suppport online to see if the parameters are near enough to do the job, but a TomTom charger works, and some Samsung ones.
That'll confirm if it is your adaptor. Some of the cheaper imports of ebay/Amazon elec adaptors aren't much cop - waits for deluge of owners who've used one successfully since birth.......:smileyplain:
Let us know how you get on.....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Is it possible to buy an adapter converter where you can use the USB port to it and be able to charge it in an outlet?
