Having problems registering my PRS-T1
profile.country.en_GB.title
willed1982
Hi All,
I'm probably being blonde, but I'm really struggling to register my new PRS-T1 e-reader online.  Everytime I type in the info, it just comes up with has already been registered. I know for a fact though that I haven't!
Any help would be most appreciated!! 🙂
1 ACCEPTED SOLUTION
Accepted Solutions
carpetmojo
It could well be that one of your "early" attempts actually succeeded, as it sounds like you had a few goes at it - it's not instant !
You could uninstall, then try again, or do a soft reset.
1 REPLY 1
carpetmojo
