Connecting smart TV to cinema AV system
I have purchase a new Sony TV, model KD-49XE7073 and connected an older Sony Cinema AV system, Model DAV-S550 to it. However the picture is only black & white - not colour.
I have used the 3 x RCA cables (red, blue, green) from the AV system to the three sockets to the TV switching colours around but no better. There are no corresponding colours on the TV for the three outlets. In addition I have connected the Optical Audio input lead.
Please can anyone suggest what is required. Thank you
1 REPLY 1
cass_n
Hi @sfilmclub4 and welcome to the community,
You won't be able to use the component outputs of your home cinema, as your TV has no component inputs.  Instead, you can connect the video out (RCA/Yellow) to the video in (RCA/Yellow) of your TV and this should solve your issue.
I hope this helps.
Cheers,
C
