Wireless speaker compatibility
Is SONY SRS-ZR5 Multi-Room Speaker compatible with music centre cmt-sx7b? If not, can anyone suggest a lower-end speaker that is compatible?
1 REPLY 1
Owen_G
Hi Sue,
Welcome to the Community. Yes - the SRS-ZR5 is compatible wit the CMT-SX7B. You can find out how to set them up together on our dedicated Wireless Audio Support page, which you can find here.
Hope this helps. Please let us know if you have any further queries.
Thanks,
Owen
