I purchased a XAV-AX1005DB which was fitted into my 2007 Golf. Whilst listening to DAB radio (more so when I’m in a poor signal area), it cuts out as the audio rewinds a few seconds then does the same but jumps forward again. It’s connected to the front windscreen DAB aerial. Would a roof mounted DAB aerial be a better option?
Or is there anything obvious I can do on the unit to stop this?
Many thanks
Martin
