4K / Dolby Atmos / HDR / Dolby Vision Compatibility
alun.67
Hello fellow forum members.
I am considering purchasing the following Sony devices:
  1. KD-55 XF9005F - 4K TV
  2. UBP-X700 - 4k Blu-Ray Player
  3. HT-ZF9 - Sound Bar
Question: Would all devices be compatible to give me 4K, Dolby Atmos, HDR and Dolby Vision when connected together.
If so what would be the correct cables and connections that I would have to purchase please?
And......  How would I connect everything up?
Thank you in advance.
Alun
4 REPLIES 4
Sean_Mc
Moderator
Hi Alun,
I'm looking into this for you and will update the thread as soon as I have an answer for you.  In the meantime perhaps another community member will be able to help.
Best wishes,
Sean Mc
alun.67
Thank you Sean, very much appreciated.
Kind regards
Alun
Win_88
Specialist
Hi alun.67,
I've just had a look on the specs of those devices, and they seem to be able to achieve what you want.
I would suggest that you setup the TV, connect the soundbar via HDMI cable to the ARC port on the TV. Then connect the video player to any of the remaining HDMI sockets on the TV.
Win_88
alun.67
Thank you for your reply on the matter Win_88.
That is good news for me.
Kind regards
Alun
