Easier way to switch from speakers to headphones?
profile.country.SE.title
SkinnyCyclist
Hi all!
Most of the time I use a 5.1 speaker setup with my KD-49XF7005 TV and STR-DH790 receiver but late nights when the family is asleep and I need to spend some time with Arthur Morgan (Red Dead Redemption II :wink: I use a pair of wireless Sennheiser RS 175 connected to the TV with an optical cable.
The procedure for switching between speakers and headphones below - Is there an easier way?
- Open the Sync Menu.
- Switch from Audio System (the receiver) speakers to TV speakers.
- Muting the TV speakers.
Thanks.
2 REPLIES 2
EdwinaU
Moderator
Hi there,
We'll check this for you and let you know what we find out. Meanwhile, maybe some of our members will have some advice to share.
Best wishes,
Ed
Almou_10
Specialist
Hi SkinnyCyclist,
I guess I can suggest two different ways to get a better setup but both will depend on connecting the headphones by a 3.5 mm headphone jack.
1- Connect the headphones to the TV directly, and activate the " Headphone Speaker Link " so that you don't have to mute the TV every time you do the same switch. ( Settings - System Settings - Setup - AV Setup).
2- Connect the headphones to the Amp directly, It should switch the audio directly to the headphones, but I guess you'll have to unplug them after you finish gaming :wink:
Hope this helps,
Almou_10
