Help needed with code for Blu Ray player for Hitachi TV
profile.country.en_GB.title
Octoberon
Can anyone advise code for use with Remote Control  RMT-B118P to control Hitachi TV? Manual says 24 which does not work.Blu-Ray BDP-S185. TV Hitachi 32" L32HK04U A
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
as far as im aware you wont be able to as the remote control in question is not a "universal" remote,and will only work with Sony tv's.
2 REPLIES 2
Bravia55HX
Octoberon
Hi, Thanks for that.it would seem to explain the problem as Sony site gives a different code to the manual,niether of which work! I'll stick with using the TV and Sky remotes to control the TV volume. Thanks again.
