Low volume arieal signal compared to external inputs
Johnboy600
Hello all
I have a xf9005 TV and bdv7200w cinema system. I am struggling with audio volume when listening to TV, the sound is very low having to run it at 70+ to get any real volume were other inputs only need to be around 45 for the same volume.
I have tired many different settings but getting no were, any help would be greatly appreciated
Tags (2)
2 REPLIES 2
Sean_Mc
Moderator
Hi John,
I'm looking into this and will update the thread as soon as I have more information for you.
Best wishes,
Sean Mc
Tenneen9000
Hi John,
There is an option available to set the volume level of the TV to one standard across broadcast and external inputs.
You can access it by going to settings-sound-sound adjustment-advanced settings and under common set "Advanced auto volume" to auto.
Let me know if this helps your case.
Cheers,
Tenneen9000
