Hi
Has the STR-DN-1080 a functionality, where you can select various picture qualities (see below- Denon 2400). I'm not sure if I keep the Sony, because there are many issues and the Denon seems to have more functionalities
Off (Default): No picture quality adjustment is done with this unit. Standard: The standard mode suited for most living room viewing environments. Movie: A mode suited for watching movies in a dark room such as a theater room. Vivid: A mode that makes graphic images for games, etc. brighter and more vivid. Streaming: A mode suited for low bit rate video sources. ISF Day: A mode suited for watching movies in a bright room during the day. ISF Night: A mode suited for watching movies in a dark room at night. Custom: Adjusts the picture quality manually.
Hi Wannagat,
There's some information about selecting picture quality in the manual here. Hope this helps,
Best wishes,
Ed
Hi Wannagat,
Best wishes,
Ed
Thanks Ed,
Thanks looks good.
But does that only work with Sony TVs
