sony bdv-n590
sony bdv-n590
Hi all,
I am trying to use an optical switch to allow me to have two optical inputs in to my reciever, unfortunately it does not work.  I have tried both devices connect directly to the optical in and they work fine.  I also know that the optical switch works as it worked on my previous system.
Does the bdv-n590 work with an optical switch? Any help or info anyone could give on this matter would be greatly appreciated!!
1 ACCEPTED SOLUTION
Accepted Solutions
Goosfrabaaaah
THat does sound odd...
Maybe your switch is faulty.
actually, I just noticed I've got this switch:
http://www.amazon.co.uk/CYP-Optical-Audio-Switcher-Remote/dp/B004VFPZZA/ref=sr_1_23?ie=UTF8&qid=1390...
4-1 with external power.
Works a treat for me...
Have you got any other device you can route through the switch?
Good luck...
6 REPLIES 6
Goosfrabaaaah
I'm using an optical switch no problem.
I've got my ps3 and tv hooked up to the bdv n590 and can switch without a problem between the two using my optical switch.
What switch are you using?
Sent from Galaxy S3 on Three
Goosfrabaaaah
Not very long. I think they are only 1m!
Sent from my iPad
Goosfrabaaaah
Good luck...
Thanks for your help! I think I might just need to purchase a new switch.
But saying that I am taking delivery of a new tv tomorrow that outputs 5.1 via its optical, so shouldn't need to use a switch. (I think!!!)
Sent from my iPad
