Sony HT-XF 9000
CloudyV
Sony HT-XF 9000
I can’t seem to get sound from HDMI / ARC from TV to sound bar when watching Netflix /internet content from TV anymore
Sky box is connected with optical cable and sound plays through sound bar ok .
I can also get sound and internet content through the DVD player connected to soundbar through HDMI.
I used to be able to get sound from ARC with some intermittent drop out. Now, nothing.
I’ve changed HDMI cables and they are high speed 4K compliant.
Is it HDMI port failure?
Is it software?
Is it settings?
3 REPLIES 3
Pascale_F
Moderator
Hi CloudyV,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi CloudyV,
I've a couple of questions/suggestions, could you try the below and tell me if this makes any difference?
Could you let us know what is the make and the model of the TV?
Also, have you tried a different HDMI cable?
Cheers,
The_Black_Rose
Darleen35
Hi  I got the same problem my sound bar wont play sound from the tv kf75 model and it is 65 inch tv
