Sound Bar or Blu Ray system with Wireless rear speakers
cpprice
Neues Mitglied
Would love some advice.
Am fed up with the wires on our old panasonic dvd system and fancy a blu ray system at the same time.
Dont know whether to get a Blu Ray player and a sound bar or
Get a 5.1 system with Blu ray and wireless rear speakers.
What do you suggest and can you recommend some of the products - it isnt easy to tell straight away which have wireless speakers.
thanks
3 ANTWORTEN 3
Anonymous
Nicht anwendbar
Hi there
The physical speakers in a 5.1 system are always better.  But the pertinent question is - What is your budget range?
PS : A quick scan indicates that only one model from this years range has wireless rear speakers : BDV-N7100W (of which What HiFi gives it a 5* rating : http://www.whathifi.com/review/sony-bdv-n7100w )
cpprice
Neues Mitglied
Sorry should have said. Less than £500 preferably.
Anonymous
Nicht anwendbar
Wireless Speaker Option
  • BDV-N7100W (2013 model) - Can be bought for around the £600 mark
  • BDV-N790 (2012 model) - Amazon lists for £425
Soundbar (2.1)
  • HT-CT260H (2013) - Approx £280
  • Add a Blu-ray BDP-S5100 - Approx £120
Before committing, always do your research, to ensure that you get the right/best product to suit your needs.
