STR DB790 No Display/Audio
profile.country.en_GB.title
rouseytastic
Hi There
I have owned an STR DB790 for a few years with no problem at all. Last week after a house move my girlfriend said she was watching TV as normal (with sound coming tthrough the amp) then all of a sudden everything went off. TV etc all work now but not the amp. It seems totally dead although there is still an audible 'click' when you press the on/off button but no sound or display.
I have changed the fuse in the plug but that hasn't worked and was wondering whether there is an internal fuse or anything else i could try?
I'd love to get this amp up and running again so any help would be great.
Thanks
Alex
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
probably an internal protection fuse gone inside somewhere.
definately worth getting it looked at.
1 REPLY 1
Bravia55HX
