annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
STR-DN860 USING SKY Q SILVER
RÉSOLU
notspurs
Membre
just wondered if any one can shed some light on why, when  using sky q silver,connected to the sat imput of the amp, i cannot get 2160 10bit to work with sky, but when connecting sky direct to tv, only then does sky connect to 10bit?  tv is kd x8509c  sky to amp, amp(ARC) to tv is my set up
2 SOLUTIONS APPROUVÉES
Solutions approuvées
Anonymous
Non applicable
Hi there
I have just had a look at the more detailed specs of the STR-DN860.  Sky Q Silver outputs 2160p at 50hz, unfortunately the STR-DN860 does not support 10bit at 2160p and 50/60 hz - only 8 bit.  See Specs below.
My advice is to directly connect the Sky Q Silver box to the TV via HDMI and pass-though the Audio from the TV to the AV Receiver.
Edit: Some further reading:
http://helpforum.sky.com/t5/Sky-Q/sky-Q-UHD-doesn-t-support-AV-amps-or-soundbars/td-p/2513407
Voir la solution dans l'envoi d'origine
notspurs
Membre
your a star! thank you very much. now i know
7 RÉPONSES 7
notspurs
Membre
just like to add,   amp is HDCP2.2 compliant, so 10 bit should work , passthro' from sky box
notspurs
Membre
was wondering if any body had an answer, or am i being completely stupid(which i don't mind being told)that nobody feels it is worth comenting on. Still dont understand why an amp that has a HDCP2.2 imput for SAT and is 8/10/12bit passthro@ compliant  over hdmi, yet you have to connect a STB direct to the tv, to get 2160p 10 bit. no point in having an amp with a SAT imput i suppose then! Just thought some nice person would explain, instead of phoning Sony to get the answer. and yes all cables are ACORD 18gbs
Anonymous
Non applicable
Hi there
Everytime I come to look at your post/issue I get side-tracked - appologies.  Having a look now, will post back soon.
Anonymous
Non applicable
Hi there
notspurs
Membre
Anonymous
Non applicable
You're Welcome :slight_smile:
Shane.h
Nouveau
Firstly is there any update for the Sony amp to be able to take sky Q,
or will there or do Sony not support there own products, as only had the amp for less then 2 years from new, yet there is 4K inputs....
