ashraf13
Flash Problem
hello. i bought a new xperia L but why i can't turn on the flash when i touch into the flash icon in camera apps??
16 REPLIES 16
sreez
Hey guys me too have the same problem.. My flash isn't working.. Guess, it is a hardware complaint.
rhino
My flash works fine but it flashes at random times when im not in camers mode its getting annoying any suggestions
zafar46
my flash and capture timing fails results in darker images
KT
I'm having the same problem with my flashlight..
Any solution????
its really annoying me cause I cant enjoy using my camera, and any flashlight apps...
I installed the swiss army knife app ( using its flashligh) and after sometime i noticed that the flash is sometimes working and some other times its not working !!!!!
mk1991
Hello friends xperia l flash stoped working after the crap updation 15.3.a.1.14 i have done a factory rest also but for few days flash had been working after tat its stopped....!!! Now i need to reset factory settings one more time to bring to the normal stage :'(
omer
Camera gives too much flash when captured pics in Xperia j wat can i do
Osprey14
I had the same problem just now: I went to switch on the torch and the button was greyed out.  I managed to get it back working -
I opened the Camera and tapped on settings where my HDR was already OFF so not sure its certain to state that it is associated to whether the HDR is on or off.  Anyway I switched on HDR mode then I switched it off just in case; then I tapped on the FLASH and in my Flash options (which were currently set to OFF) and I tapped on Torch which worked as the torch came ON and then I selected auto flash to turn it OFF.  I closed the Camera and rechecked my Torch Button which was no longer greyed out and was working again.  So the problem does seem to be associated with the Camera somehow
