- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Problem to update aps on sony L1
Hi. I have a weird problem. Cant update some of my aps. Just says that The app cant be updated. Try again. If the problem still arena there you can get hel with support. - 506
Anyone having a clue whats wrong? The only thing that seems to work are to remove The app and then install it again. But i dont want to do that, losing accounts etc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem and it seems that the only solution is to factory-set it, but it's rather frustrating to do it once a month or more often. I hope there will soon be an update that solves the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Which apps are you experiencing the issue with?
Could you post screenshots of the error?
Which version is the app on your phone?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's all apps, I can not download new apps, but as soon as it's factory-set, it works again. It seems that it's Android 7 there's the problem because there were no issues with Android 5 and 6.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's not possible with screenshots at the moment because I do not have L1 nearby, but it is reporting error code 506.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
When you do, feel free to post them here, and you can click on my screename and send me a message as a reminder.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I found out why it wasnt working for me. In my case the aps didnt update becouse i had moved them to my SD-card. As soon as I had moved them back to the phone i could update them
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I can't update apps that are on my sd card too. Have to move them to internal then back to sd card. Hopefully Sony will fix this
