amber light remote not changing channels
estherra77
There is an amber light on the TV and although I've changed the batteries and it flashes the channels don't change and the banners are on the screen
3 REPLIES 3
Please perform a soft reset of your TV by unplugging it from power for some minutes.
Win_88
Specialist
@estherra77
It would also help if you include the model number of your TV in the post so users can help you better.
Win_88
profile.country.IE.title
Eugbug
Could the TV be in the middle of a Firmware update (latest update Feb. 2nd)? According to this, an amber light flashes during an upgrade. Powering off during the installation then wouldn't be a good idea?
https://www.sony.co.uk/electronics/support/lcd-tvs-kdlxxw7xxb-series/kdl-32w706b/downloads/00017151
