- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Bravia wireless network problem
-Juha
![](/skins/images/674C5F45A266706102692146B423D792/responsive_peak/images/icon_anonymous_message.png)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Its possible isnt it - Can you confirm if everything works in a wired state?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The wireless dongle comes with a breakaway cable. Have you tried using that, and placing it a bit further away from the TV/electronics? Failing that, you could getting a replacement one, incase it is faulty.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
and it started to work. I was able to get onto the network, refresh Internet
content and got as far as seeing the BBC iPlayer screen. Then it stopped and
now I'm getting the same error messages as before whenever I try to get back
into it. L
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Which means the dongle does work - its just somewhere along the line, you have some interference somewhere, which is a bloody tricky thing to figure out what it is. First step it to use a program called inSSIDER to determine which channel is best, and then change the wifi channel on your router.
If you google troubleshooting wifi issues, you will get a load of suggestions.
The Sony Wifi Dongle is not the most powerful, and hence the range is not so great either.
I know that this is not the answer you want, but unfortuately for you though, a wifi-dongle may not suitable for your situation. Which leaves homeplugs (or a long network lead).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I noticed that I have to reboot the router after my TV is turned on. If I do it other way around, then it wont work.
But after the router has been rebooted it will work well until I switch the TV off.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If I had known these problems beforehand I would not have bought this TV which incidentally I did research and it was highly reccommended as a good buy on Currys own website!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Probably a bit late for some but I had same problem. All other devices connected to broadband hub wirelessly but Bravisa would not. Remembered had changed the channel in the SKY router from 1 to 13 some time back when trying wifi direct. Changed channel back to 1 and TV connected wirelessly straight away.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sony Bravia 49XD8099
I have used my TV once to watch YouTube. Every time I try to watch anything internet based, *I check that the internet connection is fine and "excellent". I then try to watch YouTube or whatever and it tells me it is not possible and I need to check my internet connection. Back to *. This goes on ands on. Resetting the internet. Checking I have strong signsal - it tells me I have - but it will not function. This television was not cheap. I cannot use any of the internet features on it. I have re-booted, reset the hub, tried to connect via WPS button - nothing. I have bought Sony TV's for the last 40 years. I feel rather let down. Is my problem symptomatic of the other problems mentioned here?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Chromecast device that works perfectly. The TV wasn’t cheap and, as I
recall, the Sony USB stick cost about £80 (as opposed to £30 for
Chromecast)!
