I have connect my Android Box on HDMI (2 o3). When use device in random timeperiod on top show "info banner" with information about current input, resolution and time.
This is very frustrating.
Does any find solution for this problem?
This isn't Android TV and no option for colpletely disable "Info Banner".
Please Help anyone.
HI there,
Here is a link to the answer you are looking for: http://bit.ly/2naU49H
Welcome to the community.:)
Best wishes,
M
Yes my friend, but...
That discusion is marked as Solved.
With my Sony TV model XE70 problem is not solved.
^ Everyone is giving up on this problem while sharing this guide.
They do not know, or care, about the new Driver. They do not have this option at all "HIDE INFO BANNER".
At all. Nobody cares though.
