kdl-32w706b wall mount
Hi!
i'm looking to mount my 32" Sony TV on a wall with a angled lever, and i was wondering if this would fit my TV?
https://www.amazon.co.uk/Invision-Ultra-Swivel-Bracket-Mount-x/dp/B010G6972O/ref=sr_1_6?ie=UTF8&qid=...
Along with this adapter kit:
https://www.amazon.co.uk/gp/product/B00NA9EXBK/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3PY0LT5O5X6...
Or you have any other suggestions to a similar price? It will be mounted on a plaster wall with 4 screws and plactic joints meant for plaster walls.
Thank you!
4 REPLIES 4
Anonymous
Not applicable
Hi there
I cant see any reason why it wont work.
Sony list your TV VESA dimentions of 200 x 100 - see HERE.
The tilt and swivel mount indicates that it fits that.  it is interesting that the large one is £1 cheaper that the medium one :slight_smile:
And the VESA screws seem ok.  Saw this for your TV (just the 42" model) - see HERE
My concern is the plaster wall.  That tilt and swivel mount is putting a lot of weight in one specific area...
Thank you!
I think the 100x 200 measurements are with the very expensive adapter box Sony is selling separately, because I measure the distance to be 300 x 300 approx.
The plaster wall i my concern as well, but the TV is only 7.9 kg and I bought a plaster screw kit with 8 kg pr. screw, so I think it will be okay, but i will be careful!
Cheers!
Anonymous
Not applicable
Cool - good luck with everything.  :slight_smile:
tobybump
Hi nicklasolling
How did this work out for you as I'm trying to achieve the same thing?
Thanks in advance!
