Partagez votre expérience!
I would like to know how can i go back to the original firmware of the TV , that came with before updating ???
Is a simple Reset to factory defaults enough ????
Many Thanks...
Hi NikolasP
Unfortunately you cannot roll-back firmware updates. Is there a specific reason why you need to?
Thanks for the answer....
No there is no specific reason....just from curiosity in case something goes wrong with an update, but i ve read that there are other solutions as well if something goes wrong.....
The thing is that when i first operated the TV didnt get a chance to view the Menu because immediately got the information about updating to the newer version....thats all....
Thanks !
