I am trying to access wireless internet connection in my Sony Bravia TV but it says my default built-in Wifi is OFF. Try to setup wireless network but SSID never discovered. I did Factory Rest multiple times but the issue still persists.
I seriously need to have wifi in my TV
WiFi and Wi-Fi Direct are not the same thing, keep active the first and disability per second.
Manolo
Yeah but nothing is working for me. I just need to know what is going wrong with the settings or if hardware failure. All of a sudden how come my TV lost wifi and always showing off?
I went through every possible steps mentioned in this forum and nothing seems helpful.
Any expert help?
I have no way of explaining how to get it but I would like to see a picture of you where it is Built-in Wi-Fi "On" and Wi-Di Direct "Off". Then you can try connecting to your Wireless again.
Manolo
Wifi direct is Off and Built in wifi is ON
Now while checking connection its Off
Ok, but can not find any networks?
Manolo
Yes its showing off and no networks were discovered.
At this point you should bring the TV back to the factory settings, and then try again.
Manolo
