Battery Charging
profile.country.en_GB.title
tinytan
Battery Charging
Does anyone know how to fully charge the battery on the vaio,  mine gets to 80 %  and stops.  I have the power plan set to Balanced.  Does this make any difference ?   The laptop is only 5 months old and Ive always had it plugged into the mains and not used the battery  ?
1 REPLY 1
rich912
Contributor
Hi tinytan,
This is probably due to the battery care function being enabled.
Depending on your model you can access this setting either via Vaio Control Center > Power Management > Battery Charge Settings, or with newer models I believe it is accessed via the Assist button.
Rich
Go n-éirí an bóthar leat
