can any body help me aout Use PS2 in VGC-V2S
neong
First of all i hope everyone can help me to fix this problem, i brought a new desktop on my bedroom, that is the VGC-V2S and i want to plug-in the Ps2 for game , but i cant make it to display the game normally ...
i plug in and try to play it , but it not work normally , it turn to black and wite ,and with flash in the monitor ,
can someone can fix my problem , how to fix this problem can anyone can help me pls
PS2 use in VGC-V2S
need to download anything?
or if have any method can you teach me how to do
thx so much
kaifor3@yahoo.com
2 REPLIES 2
Anuba
Sounds somehow like a Pal vs. NTSC format problem.
Is the PS2 PAL or NTSC ?
Anyway, start VAIO Zone, click settings, and try to change
somehow the videomode between NTSC and PAL until it works.
babysmile
Yup.. true indeed..
If ur PS2 is NTSC platform, i'm afraid you try to get a PAL system first in order to get the game working smoothly and colorful ..
I have try in my Sony VAIO on PS2 NTSC system .. when entering the sony ps2 start up screen it flicks and black and white .. later if you insert the PAL system DVD games and it back to normal TV specification. Even if u buy the NTSC to PAL converter which normally does the trick on TV but not on this PC.. ( but helps a bit.. )
I have no idea how to change the software in VAIO ZONE cause it's can't be change.. so take note ..
