Had anyone install the new driver Version : PFS3-2 on thier DW-D56A optical drive? Especially on A317S series... the last one was all problems so i am abit worry of installing this new driver
Thanks
Ciao
hmm look like i am gonna be the first person to install it afterall...
wish me luck :smileygrin:
Good luck Eugene!
Heh. I did, some time ago, on A317. And some reading/writing issues were solved. So It was worth for me. And in fact it's simple thing to do. Just turn off anti-virus if you have it run .exe file, and reboot after that. Nothing bad should happen.
... i decided not to update it :smileygrin: :smileygrin: wise moved..
Hey I installed the new firmware today on my A317S. No issues it works like a dream. Hopefully it will solve the issues with the reading and spinning up of discs.
Fingers crossed
Hey well tested the abilities of my drive and what do you know its worse than what it was. Looks like I will have to call support and see if it can be sorted out:smileycry:
