Dear All,
I have sent a message before before even could not get one reply. Therefore I would like to repeat my question. I own AR51SU. I hear a constant noise coming from the fan. The noise gets higher when cpu is more harder but this is not my problem. My problem is the noise I hear constantly when the cpu is for a large share unoccupied.
I have compared the noise level to one of the old Vaio GR-390 and to a more recent B series.
They are considerebly more silent. The noise is not terrible but I am not supposed to ehar it I think.
My question is: Does anyone else hear the fan in any of the AR series?
Even if it is a little bit? With respect to your answer I will send the vaio to the service.
Thanks for your reply.
I have contacted sony support but they told me that they cannot say anything without seeing the machine. Therefore I rely on the answers here. I dont want to send the computer for two weeks if it is not my problem. If this fan noise is common to all, then I will live with it.
Hence, other AR users, would very much appreciate if you can send a short reply indicating if you are experiencing the same problem.
Thanks!
P.S: why AR series is more noisy than even the older versions then?
Replying 3 years later, almost to the day! No, my AR (a 71 ZU) is almost completely quiet, just a very faint hum in the background - always, so far as I've noticed.
Mind, the room it lives in is not very warm. Meg.
