Fn keys help please
Fn keys help please
Does anyone know how to turn on and off the Fn function that makes the u,i,o,p,j,k,l,m keys turn into numbers please? I've done it by accident and now i can't type without holding down the fn key - it's really annoying!
Than2s!
3 REPLIES 3
Thalamus.
Champion
Hi quetzal_paradise,
press the Num Lk key (top right) once should turn the keys back to the correct letters..
Thank you Thalamus!!
That was so quick & simple I feel silly for getting stuck 😛
Have a good day then!!
Thalamus.
Champion
You're welcome..
It's only quick an simple if you know how, you're not the first to ask the question and I'm sure you wont be the last.. :slight_smile:
