who can help me ??? please
i bought a sony a215z notebook. i tried to make a recovery disk, but i can't finished it .
every time , when i started to make the last disk, it will say there is anerror wich tells me to destroy the DVDR and restart again.
the same problem with MR deamon, but the difference is i can make the first recovery disk, but i can't continued to finish it .
how did you solve the problem??? you know it is really a waste of my hard disk, the recovery disk takes about 7gb of my hard disk. and i doesn't allow me to del it !!!
please help me anybody!!!???beg you all!!!ha ha ha
thank you
Hi
Welcome to the Forum:smileyhappy:
Might be worth looking at Vaio-Link to see if there is an update or patch to fix this problem.
I remember seeing a fix for this but can't remember which PCs the fix is for.
I didnt solved it yet, only updates i found are the devices firmware wich didnt helped. Difference with mine is that it gives me the message after 1-2%.
As T-R suggested, there is an update for the Recovery Utility (A215Z) on Vaio-link. Have a look here.
