not working web camera and sd card reader on fz21e
profile.country.ru_GB.title
alesivac
I've just done a clean install of windows 7. on vaio FZ21e
not working web camera and sd card reader.
need correct drivers please.
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Sony do not support Windows 7 on your model - so you will need to install the Vista drivers.
FROM ORIGINAL DRIVERS PACKAGE
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-FZ21E
Ricoh Camera Driver
Memory Card Read/Write Driver
Memory Card Registry Patch
FROM ORIGINAL UTILITIES PACKAGE
VAIO Camera Utility
VAIO Camera Capture Utility
FROM UPDATES TAB
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-FZ21E
VAIO Camera Capture Utility Update
VAIO Original Function Setting
Do the FN Keys work?
:thinking:
3 REPLIES 3
Blencogo
Ricoh Camera Driver
VAIO Camera Utility
FROM UPDATES TAB
:thinking:
alesivac
thanks !
camera and reader sorted.
not sure about FN Keys
profile.country.en_GB.title
vija_y.annd
thanx, I can use the webcam in skype now.
However even after successfully installing camera capture utility,the following message is diplayed when it is opened " An attempt to initialize the camera failed. Please check if another software is using the camera".
help.
